Discussion topic: Tv apps keep stopping
This message was authored by: Dean1301
Paramount plus , Netflix, Disney all apps keep stopping and say error code every so often and it's getting on my nerves now where I'm gonna cancel and go BT if it continues
Re: Tv apps keep stopping
@Dean1301 if you are using WiFi to connect while streaming the cause is likely to be poor WiFi. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
