Discussion topic: Turning off Sky broadband shield
Message posted on 22 Dec 2023 08:33 PM
Hi I can't disable the sky broadband shield can you please arrange to have this disabled for my account
Message posted on 22 Dec 2023 08:38 PM
Re: Turning off Sky broadband shield
@SuperMonkie What devices have you tried to do this on and which browser are you using to try and turn off broadband shield?
Also, you are not talking to Sky as they don't know who you are from this forum post.
Message posted on 22 Dec 2023 10:51 PM
I'm based in Ireland we don't seem to have access I have see some sky reps addressing this issue by DM I was hoping one would get back to me and sort it.
Message posted on 23 Dec 2023 07:19 AM
Seems a common problem @SuperMonkie not sure if the Forum Escalation team can help as you are in Irelabd but Inhave escalated your post which means theyvshould respond later today.
Message posted on 23 Dec 2023 09:15 AM
Hi there! Thank you for escalating this. We have sent an invite to SuperMonkie.
Message posted on 10 Feb 2024 01:26 PM
Im also in Ireland and unable to access this setting to turn it off. Did you get this sorted?
Message posted on 10 Feb 2024 02:58 PM
@RuthMol you should be able to turn off the Shield in the My Sky app if you are using the Sky id linked to the account holder. If you definitely cant then we can escalate your post.
Message posted on 10 Feb 2024 03:06 PM
When I do that in the app I keep getting an error message saying "sorry, something went wrong" "please try again".
But when I hit "please try again" the same page comes up
Message posted on 09 Apr 2024 07:54 PM
I'm having the same kind of issue, it's telling me my broadband isn't set up yet so I can't even access the settings
Message posted on 23 Dec 2025 06:24 AM
How to turn off my sky broadband shield?
Message posted on 23 Dec 2025 07:40 AM
@Trina9 assuming you are the account holder and using the Sky ID linked to the account use the instructions here https://www.sky.com/help/articles/sky-broadband-shield-using
If you are certainyou are using the correct id and it isnt working call Sky they should take you through a security check and change tge permissions fir you. While you can turn the shield off completly leaving it on age 18 helps blocks known phishing and malwareactivity.
