Discussion topic: Trouble with my wifi
This message was authored by: jkap
have turned off my broadband box but the internet is still not working and the internet light is not showing on my hub
Re: Trouble with my wifi
@jkap
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@jkap You would be better to run the service checker incase sky have some idea what!. Run it over mobile data if you have no landline broadband!
