Discussion topic: To w it may concern
This message was authored by: Tarn
To w it may concern
My sky broadband router has only two green lights. I've try turning it off and press the reset button an I'm still only getting two green lights. Yours faithfully Tarn Robertson
Re: To w it may concern
@Tarn Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
