27 Jun 2023 11:34 AM
Hi...
At the moment I have the 1 gig Virgin Broadband but I now se that I can get Sky 900mb service at my address. I already have Sky TV.
At the moment my router is upstairs and connected via ethernet to my Mac and also to printers also situated upstairs.
I have also got an ethernet connection to my TV downstairs via an external cable !
My phone line which is also Virgin is at the front of the house.
So my question is how much trouble is it going to be when and if I change to Sky ??
Sorry for being so long winded !
27 Jun 2023 11:37 AM
Posted by a Superuser, not a Sky employee. Find out moreThe process would involve Openreach visiting and installing a new fibre cable to your home. To minimise the disruption to your setup it would be ideal to ask them to run the cable to the same place you have your Virgin router in now although they not be able to completely accommodate that.
27 Jun 2023 11:49 AM
https://www.increasebroadbandspeed.co.uk/fttp-full-fibre-broadband-installation
27 Jun 2023 11:56 AM
Hi..
Thanks for that... will Openreach install a new phone socket in a place of my choosing ? If this was at the rear of my TV I could use the existing ethernet cable to conect to an upstairs hub for my mac and printers ?
Cheers Phil
27 Jun 2023 11:59 AM
Posted by a Superuser, not a Sky employee. Find out moreCompletely depends on the engineer who attends and the scale of the job. By the book engineers will only do a run of about 5-10m from the point the cable enters/attaches to your property. However on the day the engineer may agree to putting the ONT into a location of your choice even if it exceeds the normal installation guidelines.
27 Jun 2023 12:04 PM
Hi.. The telephone pole is right at the front of the house about 5 metres away.
27 Jun 2023 12:07 PM
Posted by a Superuser, not a Sky employee. Find out moreIf the closest point of your house to the telephone pole is within about 5m of where you want the hub then you'll be fine. If it isnt then you may need to sweet talk the engineer with some tea and biscuits
27 Jun 2023 12:07 PM - last edited: 27 Jun 2023 12:18 PM
Note there's no 'phone socket': the Openreach-supplied kit is an Optical Network Terminal (ONT).
The only connection for landline telephony is on the ISP-supplied router. Any Openreach sockets, extension sockets and Virgin telephone points become obsolete.
27 Jun 2023 12:50 PM
Many thanks and have a nice day ! Cheers phil
