Discussion topic: There is a problem with broadband
Message posted on 03 Nov 2025 10:41 AM
The last two days there is an issue with the broadband. It's not working
Message posted on 03 Nov 2025 10:45 AM
Re: There is a problem with broadband
@Konnie19
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
