Discussion topic: The open reach box
This message was authored by: Sadaf
Message posted on 24 Jun 2025 06:09 PM
The open reach box
The open reach box has switched off and now WiFi doesn't connect properly
Message posted on 24 Jun 2025 06:15 PM
Re: The open reach box
@Sadaf If it has switched off did it do it by itself, have you tried and tested that the power socket is good, no lights is no power, psu or the ONT faulty or ONT switched off if it has the on/off switch on the bottom!
