Discussion topic: The hub has orange lights
This message was authored by: Ianmoses
This keeps happening when I check online with sky I am told everything is connected but it's not no tv or anything
Re: The hub has orange lights
@Ianmoses
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
