Discussion topic: Terrible wifi
This message was authored by: Xanderlawz89
Terrible wifi
Signal caps out at 100mps which is way below what I'm paying for and has been constantly low and disconnects often since I upgraded my package.
Re: Terrible wifi
@Xanderlawz89 technically you are paying for a guaranteed speed to the hub not to devices especially if using WiFi.Most apps can only use less than 100Mb/s as for example streaming Netflix in UHD only requires around  25Mb/s.
If you feel you need higher speeds then you will need to invest in your own WiFi equipment as Sky's WiFi Mx only guarantees 25Mb/s in all rooms. Loads of systems to choose from but consider your actual usage rather than fixating on out right speed as stability is more important in getting a good user expereience.
