Discussion topic: Terrible speeds
This message was authored by JayJT This message was authored by: JayJT
Terrible speeds
We pay for a very expensive package yet receive the bare minimum across our house.
Speeds upstairs are sub 1Mbps all a sudden.
I have no idea what any of it means but I've seen a few other posts asking for router stats. Here is ours:
Re: Terrible speeds
@JayJT
Can you run a speed test using an etherneted device using fast.com or nperf.com close to the router with nothing else downloading and post the results
JayJT
Re: Terrible speeds
Speeds directly next to the hub perform great. They're not the speeds were were offered - but still decent regardless.
Here is Fast.com:
And here is nperf.com:
Here is also a complimentery google one from upstairs (no ethernet):
Re: Terrible speeds
@JayJT
Which Ultrafast service are you actually contracted on?
All domestic broadband is highly asymmetric when running correctly, so the speed of that outbound link suggests the inbound is significantly slower than it should be
JayJT
Re: Terrible speeds
Not quite sure why those images didnt upload.
I'll just provide the info via text.
-Fast.com gave 420 Mbps
-nperf.com gave 98.80 Mb/s download, 72.19 Mb/s and 6.8 Latency
-Google (from upstairs and no ethernet) gave 1.68 Mbps download and 26.2 upload.
JayJT
Re: Terrible speeds
Sky Broadband Ultrafast Plus
Re: Terrible speeds
@JayJT
OK: Ultrafast Plus is a nominally 500Mbs service, with, I believe, a 400Mbs minimum.  The fast.com result would be as expected for that service.
Re: Terrible speeds
@JayJT
Are you using the same device for both speed tests?
Re: Terrible speeds
@JayJT
As @cookiemonsteruk indicates, the device used is really significant: my 500Mbs BT FTTP 'tests' as over 400 Mbs from a modern laptop and 30Mbs in the same location using my smartphone.
It's also important to understand that speed delivered upstairs over WiFi is not covered by the same Guaranteed Minimum: no ISP does that because local WiFi is too affected by factors outside their control.
JayJT
Re: Terrible speeds
@TimmyBGood @cookiemonsteruk
Yes, both tests were ran using my laptop.
"It's also important to understand that speed delivered upstairs over WiFi is not covered by the same Guaranteed Minimum" I completely understand but this sudden change in performance over the weekend is still a too drastic to say the least, right?
I mean, the speeds upstairs certainly weren't hitting sub 40 (let alone 1 Mbps and below) prior to saturday.
As a side update, we have someone coming to check things out on Tuesday.
