Discussion topic: Terrible internet connection
Message posted on 20 Aug 2026 01:56 AM
For the past two weeks the internet's been jamming. Now there's no internet connection. My speed should be 300 and it's in the 99 range. That's disgusting.
Message posted on 20 Aug 2026 08:09 AM
Re: Terrible internet connection
@Daisyme howxare you measuring speeds? If it is on a device connected bybWiFi you sre likely to be measuring thecspeed of the WiFi link in your home which Sky cannot guarantee as the layout of your home is the main deciding factor.
Sky measure your broadband speed daily and you can find tge results in the My Sky app servicechecker setting. If that is showing speeds between 90 to 100Mb/s it is most likely due to a faulty cable between the hub and the ONT. Buying a repkacement Ethernet cable from a supermarket or on line should sort that. .
