Discussion topic: Terrible broadband
Message posted on 03 Aug 2026 09:38 PM
Terrible broadband
Iv just had sky broadband installed and the signal sucks. I keep getting disconnected having to join the wifi over and over.
Message posted on 03 Aug 2026 10:22 PM
Re: Terrible broadband
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
