Discussion topic: Telephone point
Message posted on 17 Sep 2025 06:54 PM
Telephone point
I need to have a telephone point installed in my house
Message posted on 17 Sep 2025 06:56 PM - last edited: 17 Sep 2025 06:58 PM
Re: Telephone point
@Essex62 Your post has been moved from the stream board as this is not a Sky stream puck related issue. Your duplicat post also on the stream board has been removed as you don't need to raise this twice.
Message posted on 18 Sep 2025 07:45 AM - last edited: 18 Sep 2025 07:46 AM
Re: Telephone point
If you've ordered Sky Broadband then installation of the appropriate circuit is part of the process. Neither the national network maintainer or any ISP installs internal extensions.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
