Discussion topic: Technical issue
This message was authored by: Florentina06
Message posted on 17 Aug 2026 04:10 PM
Technical issue
Our wifi seems to be working however our ring doorbell and printer are not working and it says it is due to a wifi connection issue. What can i do about this?
Find out more
Message posted on 17 Aug 2026 04:28 PM
Re: Technical issue
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
