Discussion topic: Technical fault
This message was authored by: Nicholas67
Technical fault
I have the main screen on my telly and I click onto a program and the screen goes black and then comes up with there is a technical fault, we are trying to fix
Re: Technical fault
@Nicholas67
Is your TV a Sky Glass one, or do you have Sky Q or Sky Stream ?
