Discussion topic: Technical Fault on TV
This message was authored by: David2201
I keep getting the error message, "There is a technical fault. Please try again later".
This is happening now on all channels and I have followed the instructions of resetting everything and is still the same.
All our other devices are working fine so doesn't appear to be a WiFi problem.
The channels do come on but lasts only a few minutes then the screen goes blue and this error message appears.
Anyone experiencing the same issue?
My Sky app has identified there's a problem but the fix hasn't helped.
Re: Technical Fault on TV
@David2201
What TV service do you have with Sky ?
