2
This discussion topic has been answered Discussion topic: Taking up sky max wifi
This message was authored by: Jackalo
If I choose to upgrade, to the above, assuming it's £8 month, I see that the sky boost is removed, therefore basic maths tell me I won't be paying the £3 a month and my bill increase overall will be just £5 more expensive. Appreciate I'm actually paying £8 but not the sky boost £3 on top as well?
many thanks
Avatar for Jackalo
Level 4 icon
This message was authored by: Jackalo Answer
Re: Taking up sky max wifi
Thank you
So a net increase of £5 outgoing but £8 to aquire👍
@Jackalo Sky Max replaces the sky boost in all it's functions, and normal cost is £10 month, so you have been given some discount but the £3 does not go away because you cancelled boost, just get's absorbed into the Max extra price....
What you get is all explained below. So if you had £3 for boost that goes and get's replaced by £8 for the Max.
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
Avatar for Jackalo
Level 4 icon
Thank you
