This discussion topic has been answered Discussion topic: TV keeps dropping off WiFi
Message posted on 11 Dec 2025 06:50 AM
Message posted on 11 Dec 2025 07:22 AM
@Whtyl go into the settings on your Sky Glass TV and find the start up and standby setting and change the setting so the set stays networked in standby and also turn off network power saving. While in the settings check that the Network section is showing the WiFi connection as Good or Excellent.
The first step should improve reliability on start up. If the WiFi signal iis not good enough consider getting a WIFi extender which Sky will supply if requested if you buy their WiFi Max package,
