Discussion topic: TV connextion
Message posted on 01 Sep 2026 03:12 PM
TV connextion
My tv connection is poblemyatic
it does connect but can lose the WiFi for no reason.I have a problem with YouTube can u help?
Message posted on 01 Sep 2026 03:27 PM
Re: TV connextion
@Riverside1 two possible causes first is thst if you have a whitecSky hub the TV struggles with the default WiFibsecurity setting of WPA3-T iin which case findctge hub's advanced settings in thecproduct setting area in the My Sky app and hange the security setting to WPA2
Thexsecond is simply poor WiFi signal level. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
