Discussion topic: TV box will not connect
This message was authored by: Jason184
Last night internet connection with my tv stopped. I have tried for some time to reconnect but it will not happen. I have turned off for 5 minutes and gone through the connection instructions several times. No joy
Re: TV box will not connect
@Jason184 if other devuces are connecting normally there is little you can do beyond rebooting the hub and your streaming device. If you have a Sky Stream puck call Sky if still stuck as they should replaceca faulty puck.
@Jason184  WHich TV Box do you have as Sky have 3 different types:
Sky+HD, Sky Q and Sky Stream
