Discussion topic: System very slow
This message was authored by: LAndyW
System very slow
Hi, despite your checks that suggest everything is good, since moving across to you from BT, the performance has not been at all good. Especially when making online payments that are often failing due to being timed out. Why is this please?
Re: System very slow
@LAndyW you are not talking to Sky when posting in this forum. The most likely cause is that the WiFi coversge is not as good as youbhad with the BT hub which is a common complaint. If you suspect tgat is the case then call Sky andxask about their WiFi Ax add-on which can getvyou up to 3cWiFi extenders see https://www.sky.com/help/articles/sky-wifi-max
Othe
