Discussion topic: Switching to own broadband
This message was authored by: anlloyd
Hi all
I currently have Sky Q and Sky broadband but am moving over to Vodafone for broadband as it's cheaper, and they offer the 1.6gig product which I need for work.
Currently I run the Sky hub with a TP link mesh network off a rj45 port. The TP link will become the primary network when I switch over, Vodafone don't need me to use their router.
Might be a bit random, but when I switch over can I just reverse the set up and plug the sky hub into the now primary tp link router?
The sky network will only be used for Sky Q but if I can just use the hub that way it would make the switch a lot simpler 😁
