Discussion topic: Switched router off as red light
Message posted on 15 Nov 2025 12:25 PM
Message posted on 15 Nov 2025 12:35 PM
Re: Switched router off as red light
@Barb09 Few help links for you below!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to displayed by the software test! This should determine if there's an identified fault affecting multiple households.
Message posted on 15 Nov 2025 12:36 PM
@Barb09 First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
