Discussion topic: Switch to Sky did not cancel my previous provider service
Message posted on 02 Sep 2025 09:39 PM
Message posted on 02 Sep 2025 09:57 PM
Re: Switch to Sky did not cancel my previous provider service
This is a community where customers help each other so you are not talking to Sky.
If the service at your previous supplier was not cancelled then you will need to do this yourself to get is sorted. Finding out to bame is going to be trickier as the chances are they will both blame each other.
Message posted on 03 Sep 2025 10:17 AM
@Mataksim Know it's a bit after the fact, but as soon as sky confirms your order, you should also be looking out for the other ISP confirming to you also that sky are going to be taking over, not sure if Hyperoptic as an altnet are part off the OTS process so have a look or try to find out, with the process it's just not 100% working as yet and the company running the OTS are aware off this also! Good luck getting either one to fess up but do keep the Forum updated to any findings!
