Discussion topic: Switch from Virgin to Sky
Message posted on 02 Feb 2025 04:18 PM
Hi, I am considering switching from Virgin to Sky, and understand that Sky uses a different infrastructure to Virgin.
When I go through the set up on the website to purchase Sky, it is defaulting to Remote Activation. However, I only have the Virgin Connection Box in the House, and not the Openreach connection that the hub will need.
Outside I have an overhead cable coming from a telegraph pole to my house, but there are breaks in the cable as it comes down the wall. So I assume they will need to re-run a new cable and fir the relevant socket inside my home? How do I ensure that this is done before the switch over from virgin to Sky as I don't want to be waiting days for Broadband while waiting for an engineer to be scheduled in.
I looked on the Broadband Checker and the following information is shown for my home:
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential OH Dpole Hoist required.
FTTP is available and a new ONT may be ordered.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
any help would be gratefully received.
Message posted on 02 Feb 2025 04:27 PM
Re: Switch from Virgin to Sky
The table above those notes would be helpful
At the minute you will need an engineer visit to run fibre to the house and install an ont
Best to actually call sky to place the order
Message posted on 02 Feb 2025 04:38 PM
Hi @cookiemonsteruk
I figured that I would probably need a new cable run through and a socket, I will call Sky tomorrow.
this is the table above does this make sense? if there is relevant info that I need to supply Sky, I would be grateful if you could advise
Regards
Message posted on 02 Feb 2025 04:41 PM
Aye call sky as its a fttp install requiring a hoist for the telephone pole
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
Message posted on 02 Feb 2025 04:49 PM
I would suggest that you order Sky as an additional service, stressing that point when you order. That way you have the backup of the Virgin service if there are any delays from Openreach. Worst case you'll pay both for a month after Sky goes live. I've seen too many reports of Openreach running into issues or simply not turning up on the day, but the existing service being terminated anyway.
Only potential issue with that is if you have telephony from Virgin, as you'd then need to port the number across to Sky. Although that's never guaranteed anyway.
Message posted on 02 Feb 2025 05:15 PM - last edited: 02 Feb 2025 05:19 PM
For reference, the significant information is
As noted above, the requirement for this specific and somewhat specialist equipment does raise the distinct possibility that any promised installation date might well slip.
