Discussion topic: Surround sound does not connect to tv
This message was authored by: Pete_121
Since the upgrade to super hub my Samsung surround sound speakers do not connect to Samsung tv. Says wifi channel dfs does not support surround
Re: Surround sound does not connect to tv
@Pete_121  If you have the new Max white hub you will have to go into the router settings and lower the Wi-Fi security from WPA3 to WPA2 , It then should see the Wi-Fi to connect.
