Discussion topic: Stuttering and freezing
Message posted on 06 Dec 2025 06:05 PM
Message posted on 06 Dec 2025 06:09 PM
Re: Stuttering and freezing
@Afsana123 it is worth checking thst there isnt a problem with your connection by looking at the service checker in the My Sky app. If thst looks ok then your issue is likely to be poor wifi signal in the rooms where devices sre misbehaving.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
