3
This discussion topic has been answered Discussion topic: Strength of Signal
This message was authored by: JohnGriff
Strength of Signal
The  strenth of our Wi fi signal drops off as I move through the house.
Using my laptop to check the signal I have moved in a straight line away from the router.  All indoors, in a straight line  and no obsticles.  The signal drops from strong to medium after six metres and down to weak after a further ten metres.  So, sixteen metres to go from strong to weak.
It this what we should expect?
John Griff
This message was authored by: stereohaven Answer
Re: Strength of Signal
I think the honest answer is "it depends".
Obstaces to WiFi don't have to be physical walls or floors, it can be other devices, neighbours WiFi etc. Then there is checking if the drop off only effects the laptop or is it the same on all devices?
Which band is it is another question I suspect, because lower bands like 2.4ghz are slower but cover greater distance than 5ghz, the router could be faulty, it's hard to know really.
There are some tips here to start with, which could lead to an engineer appointment if needed. I believe they carry equipment these days to help diagnose issues more easily than the old days: Sky Help: Improving your WiFi signal
@JohnGriff
Try going through this to see if it helps as it might be worth rebooting your broadband hub if you are yet to do this so that when it loads backup it looks for the best channel to transmit the signal on:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If doing this has not helped and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Essentially yes: WiFi decays over distance as an inverse square
Excluding external factors such as local interference or intervening material, at double the distance, signal strength is 1/4th of the original
