Discussion topic: Stream puck won’t connect to internet
This message was authored by: Ggwazza
Sky puck is connected to broadband router, but not Internet. Multiple resets and following guidlines it just keeps disconnecting. Has been doing this since getting sky package. Considering cancelling due to constant issues. Haven't been able to watch a show on tv channel without disconnecting mid way.
wifi works fine on other devices in house, just not on stream puck.
Re: Stream puck won’t connect to internet
@Ggwazza Is the puck connected to the sky Hub by a wired or a wireless wifi connection?
Avatar for Ggwazza
Wireless at present as it means pulling the TV off the wall to connect it via cable. The router is in same room also so no concerns for distance between the 2.
@Ggwazza So where did you stick the puck then direct behind the TV?
Avatar for Ggwazza
No, the puck is on a shelf just next to the TV.
@Ggwazza Are you trying to pull the wool over then, the Ethernet connection is on the Puck!
This message was authored by: Malloy
I have the exact same problem I telling everyone to avoid sky TV at all costs as u can't watch anything without the stream puck losing connection every ten minutes or so.
@Malloy oddly myself and a few million other customers watch TV everyday using Sky Stream pucks with no significant issues. I have had 3 pucks and a Glass TV since launch in 2021 with less issues than tge Sky Q system it replaced.
However you do need a decent stable data cinnection whether by WiFi or. Ethernet that can deliver around 30Mb/s if you want to watch in UHD. You can easily check the connection quality and speed to the puck. The WiFi connection quality is shown the Network settings and you can test the speed by running the Network test in the Get Help menu of the Netflix app.
My Internet is 300 mbs or near as when I test it cabled to router  plus when I checked other forums its a known issue just wondered if u gonna get round to fixing it. I think it cheeky of u to just imagine I'm making this up but sadly no this has been ongoing since installing sky
