Discussion topic: Stream Keeps Freezing
This message was authored by: NewbieGraham
Message posted on 29 Mar 2026 08:15 PM
My Freely Tv Stream, with no arial connected keeps Freezing. I'm on 500Mb Hub with Wifi Switched off, with 3 Mercusys mesh Wifi routers. I had no problems before I went to sky from Virgin Media. Is anyone else having the same problem out there, I think it is when sky are checking the Modems connection.
Find out more
Message posted on 29 Mar 2026 09:30 PM
Re: Stream Keeps Freezing
@NewbieGraham I assume you have Sky broadband. I'll move your post to the Broadband forum.
