Discussion topic: Stopped working
This message was authored by: Juliey76
Stopped working
My broadband is not working, it was an hour ago but it's stopped working.
Re: Stopped working
@Juliey76
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband isn’t working after 7am use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
