Discussion topic: Static ip on lan
Message posted on 15 Sep 2026 11:12 AM
Static ip on lan
Message posted on 15 Sep 2026 01:27 PM
Re: Static ip on lan
@KevD2021 one method is to use the Sky Max router's web interfacecatv192.168.0.1 the log in is admin as the user and the default wifi password as the password.
Once in the web interface navigate to the connection section then local IP config. On thst ppage you can edit the end sddress for the hub's DHCP server I use 192.168.0.100 which means Incan assign addresses for devices needing a fixed IP address starting at 192.168.0.101 up to 192.168.0.254.
Message posted on 15 Sep 2026 11:09 PM
Hi Chrisee thanks for your reply. I can limit the scope of the dhcp ip range but I don't have the ability to set a static ip address on all the devices I need it on because they don't have that option in their software. I don't suppose there's another option is there?
