Discussion topic: Static Middle Amber Light on Hub
This message was authored by: Steven132
No devices are able to connect to hub. The middle light is static Amber. Tried all reset and switch on/off steps.
Re: Static Middle Amber Light on Hub
@Steven132   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
