Discussion topic: Stability issues on full fiber
Message posted on 18 Jan 2025 04:55 PM
We have installed a camera device to our small bungalow that keeps dropping out due to the internet. We are two people with only 6 devices on the Wi-Fi (2 of which are not at the house during the day and it keeps happening and not recording/monitoring). We have also installed a Wi-Fi booster just in case this was the problem but it didn't help so we then checked stability and it's very poor, please advise on how to solve?
Message posted on 19 Jan 2025 07:34 AM
Re: Stability issues on full fiber
@Dawn124 the great advantage of full fibre is its far greater stability so your fault in unusual. It should not be an issue due to load on the hub from what you say but is most likely flaky wifi particularly if the cameras are outside your house. How have you checked the stability? You mention you tried acWiFi booster was this supplied by Sky or was it one you had? Unfortunately thecwrong booster can cause more issues than it solves
