Discussion topic: Splitting 2.4Ghz and 5Ghz wifi on SR312 - possible ?
This message was authored by: Dozer302
Message posted on 06 Sep 2024 10:06 AM
I have a new SR312 router and the wifi setting are controlled by the My Sky app for some godforsaken reason... so is there a way to split the 2.4 and 5Ghz wifi SSID's ? Or do I have to turn off the 2.4Ghz and use a Unify AP ?
I have a bunch of home autoamation devices that don't play well with this config.
Doz
Find out more
Message posted on 06 Sep 2024 10:18 AM
Re: Splitting 2.4Ghz and 5Ghz wifi on SR312 - possible ?
It's not possible to unsynchronize the two bands on the Max Hub. Temporarily disabling 5Ghz is a crude workaround to try and get IoT devices associated correctly.
