Discussion topic: Speed test showing 25Mbps
This message was authored by: Rostron
Recently my speed tested on iPhone from the router is only around 25Mbps but it has been around 70-74 over the past few years
my router is in the longe so there is no distance issues.
even when only one device connected it's still lower than it should be.
I have done all the Sky recommended tests which do not show any issues.
can anyone give me advice
Re: Speed test showing 25Mbps
@Rostron Have a look at your service checker then broadband > to expand and see, will show you what sky see's to your connection incase you have a line fault!
