Discussion topic: Sophos Connect VPN
This message was authored by: AndyP-77
Message posted on 19 Dec 2023 09:51 AM
Sophos Connect VPN
Hi,
Having trouble with Spohos connect VPN connection. Seems to be ok for maybe a minute or so then slow down and disconnect. Tried with wireless and ethernet connections to sky hub with the same result.
Works ok on other wifi access points but not through my sky broadband at home.
Wondering if anyone has the same issue and hopefully found a fix. TIA
Find out more
Message posted on 02 Jan 2024 12:59 PM
Re: Sophos Connect VPN
Hi @AndyP-77
Have you tried the following;
- Restart hub
- Switch off Sky Shield
- Disconnect other devices while testing
- Switch off hub for 30mins to get a new public IP
I am NOT a Sky Employee
