Discussion topic: Snapped fibre cable
This message was authored by Pen01535 This message was authored by: Pen01535
Snapped fibre cable
Morning
 I've sapped my cable and wanting a replacement.  Minefield to which one I buy any advice wond be greatfully recieved
 this is the router that I have. The lead only has two wires and everything coming upto buy has 4. Does this matter?
Re: Snapped fibre cable
@Pen01535
That's not a 'fibre cable' : it's an RJ11 to RJ11 'modem lead' or 'dsl cable'.
Two wire is typically fine, but four wire tends to mean better quality manufacturing.
This message was authored by mormegil This message was authored by: mormegil
Picture is a bit blurry but it looks like the one with the square connection on each end? if that is your rj11 adsl data cable then you can use any that you find
most super markets sell them  or you can get from hardware stores or curry's etc
https://www.currys.co.uk/products/logik-lrj1110m23-rj11-adsl-cable-10-m-10234966.html?searchTerm=Ads...
@Pen01535
You'll also need to either pry out that detached RJ11 plug or purchase a new plug-in micro filter: the latter might be preferable if it's had a yank hard enough to break the cable.
Pen01535
Thanks  I've purchased this one so Hope fully it'll work
