Discussion topic: Smart tv not connecting
This message was authored by: Yvon2
Message posted on 04 Oct 2026 08:39 PM
Smart tv not connecting to internet. Can't log on to channels or apps
Find out more
Message posted on 05 Oct 2026 07:26 AM
Re: Smart tv not connecting
@Yvon2 assuming other devices are connecting properly go into the TV's settings to see if you can restablish the connection. Some TVs have issues with the WiFi security level that Sky's white hubs use by default. If you suspect that using the My Sky app find the hub's advanced settings page and change tge setting from WPA3-T to WPA2
