Discussion topic: Slow wifi
This message was authored by: Bikes
Message posted on 24 Apr 2026 10:17 AM
Slow wifi
I have to power cycle router frequently for iPads etc. There are times when even viewing Tv via puck is poor.
Find out more
Message posted on 24 Apr 2026 10:25 AM
Re: Slow wifi
If you have a poor signal then try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
