Discussion topic: Slow wifi
Message posted on 29 Nov 2025 09:44 AM
Slow wifi
Wifi is show just set it up yesterday and doesn't even come up as option for the wifi in other rooms
Message posted on 29 Nov 2025 09:49 AM
Re: Slow wifi
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 29 Nov 2025 10:12 AM
Re: Slow wifi
@Itihaas A single sky Hub may just not be able to push wifi everywhere that it is needed, especially if in the corner of one room and then you the etreme is just too far away! Would be good if you can say, white or black sky hub!
