Discussion topic: Slow wifi
This message was authored by: Joanne12345
Slow wifi
I was previously with bt on same package but have swapped to sky and my WiFi is really slow and doesn't connect in some rooms
This message was authored by: Gavin1980
Re: Slow wifi
How did you rectify this
Re: Slow wifi
@Joanne12345
The Sky hub and BT hub are not the same so variances in range & speed can happen. If you have weak spots in your home you can request boosters from Sky providing you have the WiFi max addon.
I am NOT a Sky Employee
