Discussion topic: Slow speeds
Message posted on 07 Apr 2026 05:11 PM
Slow speeds
Upgraded from fibre 500 to fibre GigaFast. Speeds however have become even slower! App shows speed to the hub is just under 600Mbps, however all my speed checks are showing less than 150Mbps. Prior to the upgrade, I was getting speeds of at least 3/400. Customer service as useless as ever.. does anyone have any tips or advice? Still using the old black router from 5+ years ago, cannot get the newer max hub unless I pay EVEN MORE per month.
Thanks in advance.
Message posted on 07 Apr 2026 05:57 PM - last edited: 07 Apr 2026 05:58 PM
Re: Slow speeds
Presumably a Sky Broadband Hub (released in 2019). Those pre-dates gigabit FTTP and are specified to WiFi 5, so although they can sling the full speed over ethernet cable they aren't going to do so wirelessly.
Having said that, Max Hubs actually being worse is one of the most common posts here...
Message posted on 09 Apr 2026 07:44 AM
Re: Slow speeds
Yes, it's the old SR203. A replacement was sent as they said that was the issue.. and still only getting 140Mbps despite speed to the hub supposedly being at 680Mbps
