6
This discussion topic has been answered Discussion topic: Slow speed
This message was authored by: Arron811111
Slow speed
My speed is 24mbs my package is 500
Re: Slow speed
@Arron811111 you should seexspees around 500Mb/s over a gigabit Ethernet cable. However if your device is connected by WiFi speedtests will report thecspeed of the link from the device to the hub unless thst is faster then 500mb/s. Given WiFi speeds are determined primarily by the layout and type of construction of your home they are often slower.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
Re: Slow speed
Avatar for Arron811111
Poor Internet speed
Poor Internet speed. Sky says it's fine playing for 500 and not getting 50
Re: Poor Internet speed
@Arron811111
No need for a new thread. You asked this a few days ago and advice was provided.
@Arron811111 wrote:
  • Il post on whatever thread I'm able too
Then you should expect those posts to be moved or deleted.
It's your choice whether or not to act on the advice given, which was correct.  Just repeatedly posting here cannot resolve your issue.
This message was authored by: HenrySuddes
Re: Slow speed
There's no fiberoptics in this area
slow speed internet dips and out absolutely rubbish, in going to stop my payment,
Re: Slow speed
@HenrySuddes
Very unwise. It will cause you additional problems. The relevant services will be restricted, you won't be able to call Sky, the account can't be cancelled, late payment fees will be added and eventually Sky could involve a debt recovery company which may affect your credit rating.
@HenrySuddes wrote:
slow speed internet
If the broadband has become slow see this link
