Discussion topic: Slow green light
Message posted on 12 Dec 2025 12:44 AM
Slow green light
Message posted on 12 Dec 2025 05:28 AM
Re: Slow green light
@ADMoule
Any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Message posted on 12 Dec 2025 07:44 AM
I'm the same tried everything all morning but cannot resolve... I need my connection for work how to I get urgent help!?
Message posted on 12 Dec 2025 07:48 AM
So if yours hasn't come back on use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
