Discussion topic: Slow flashing green light
Message posted on 29 May 2026 11:19 PM
How many people are having this issue? WIFI was working fine all day then started to be really slow and then went off, done everything it says to do such as restarting, unplugging etc etc! And still nothing been over 2 hours now and it doesn't help that when you run the service checker it says everything looks good when clearly it isn't good! And it's almost impossible to log issues with sky and are told to post in here for a "super user" not someone that can actually fix your issue to copy and paste links and steps you've already been through before needing to log an issue 🥲
Message posted on 30 May 2026 05:08 AM
Re: Slow flashing green light
At the time you posted the phone lines would have been closed. You can contact Sky in the morning.
The service checker doesn't necessarily disclose a problem immediately and there can be an hours delay before it picks up a lost connection which is why on here we tend to advise on trying it again later.
