Discussion topic: Slow connection/speed
This message was authored by: Julie+UK
The bloody xbox speed is soooo slow. Did a check on it and it says all is good....well, all isn't good and it's been glitchy and slow for months
Re: Slow connection/speed
@Julie+UK wifi speeds will vary around your home so bring a phone or similar near tgecxbox and run a speedtest or better use a free app called WiFi Sweetspots which will help you find the best places to get a good connection and where to avoid. While you can use a booster to improve connectivity in the area the xbox is placed a better solution for gaming is using a set of powerline adapters thst use the house's mains wiring to improve connectivity.
