Discussion topic: Slow broadband speed with stats attached
Message posted on 29 Dec 2023 03:53 PM
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 1268109 2043392 0 716376 572269 01:10:05 LAN Up 1927364 1225194 4671 2196349 788210 01:12:32 WLAN (2.4 GHz) Up 16506 0 0 416 0 01:10:34 WLAN (5 GHz) Up 49067 15919 0 2885 1514 01:10:33
These are my stats. My speed is showing as very slow for the last week or so. I've done all the checks and connections are fine.
Thanks for any help I can get!
Message posted on 29 Dec 2023 04:51 PM
Re: Slow broadband speed with stats attached
39999 inbound is typically indicative of artificial line capping, and at only 800kbps outbound you've got next to no upload speed, which won't help at all: that should before like 10000 even with a capped connection.
Message posted on 29 Dec 2023 06:54 PM
@TimmyBGood Thanks for the reply. How do I go about getting it fixed? I'll try and get hold of Sky. I'v already had an engineer out in the last couple of months as there was a fault on the line.
Message posted on 29 Dec 2023 06:57 PM
I'd suggest the fault is still there. If they quibble, you should emphasis that an FTTC outbound speed of only 800Kbs is essentially unusable
