Discussion topic: Slow and Stopping
Message posted on 13 Jan 2026 10:58 PM
Slow and Stopping
Getting really frustrated with the BB now. I've had sky for about a year. Nothing has changed in my household usage in all that time. I'm being thrown out of Teams calls, smart TV is freezing and even browsing can be really slow.
I'm convinced it's nothing my end due to nothing changing however checking my BB speed, everything is fine.
Can anyone help!?
Message posted on 13 Jan 2026 11:31 PM
Re: Slow and Stopping
@Tez Something must have changed, so what happened a year ago to cause all off this?
Message posted on 13 Jan 2026 11:38 PM
Absolutely nothing. No new devices. Work at home the same amount. Its just getting worse.
Message posted on 13 Jan 2026 11:53 PM
@Tez With nothing changed have you ever called or reported the issue to sky previously? It does sound like you problem is more wireless wifi related, but could also be the connection you have! If you wish to test then the info is linked below for you!
Try running the line test here to see if any faults are found:
