Discussion topic: Slow WiFi
Message posted on 06 Oct 2025 05:23 PM
Slow WiFi
Hello,
Since getting the WiFi the speed has been horrible on all my devices. It does not feel like I have gotten a 500mb speed as sometimes the WiFi signal on my phone, TV and laptop is very bad.
Message posted on 06 Oct 2025 05:40 PM - last edited: 06 Oct 2025 05:41 PM
Re: Slow WiFi
@Jenn22 What sky hub are you using, black or white!
Message posted on 06 Oct 2025 05:56 PM
Re: Slow WiFi
Hi it's the white hub
Message posted on 06 Oct 2025 06:05 PM - last edited: 06 Oct 2025 06:07 PM
Re: Slow WiFi
@Jenn22 Have a look at the wpa setting with your app, link below will guide you! Its the wifi security settings...
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
Advanced settings
If you're looking to manage more advanced settings like...
- Disable WiFi
- DMZ
- Port forwarding
- WiFi security levels
